EdGI Barrels
Esteban
EdGI Barrels
Post by Esteban » Sun May 23, 2010 3:08 pm
Hello all,
I have a KWA M4 RIS (2nd Gen), and I have noticed my stock KWA barrel has a couple shards of metal hanging down around where the hopup bucking protrudes into the
barrel. I have shot into a pillow and inspected my BBs, and a couple of them come out scratched. I see this as an opportunity to replace the barrel with a better one.
The KWA barrel is 395mm long, and this length matches up perfectly with the flash hider I currently use. The only 395mm long barrels I have seen have been....
http://store.kwausa.com/edgi601mminnerbarrel395mm-3.aspx
http://store.kwausa.com/edgi601mminnerbarrel395mm.aspx
The EdGi 6.01mm and 6.03mm tightbore barrels sound like a good buy. But I was wondering who here has used them and whether or not you recommend them.
What is the build material of these barrels? They look brass to me, but does any one know for sure?
Thanks for reading,
-Scott
Jeremy314
Re: EdGI Barrels
Post by Jeremy314 » Mon May 24, 2010 6:31 am
I haven't used the EDGI barrels yet, but after watching some vids and with stock KWA 2GX 6.05 barrels I say go with the 6.01 as you won't see a big difference between 6.05 and 6.03s.
I am planning on getting a 395 6.01 for my G36 when I finally change it over the the K length front end.
von_lounger
Re: EdGI Barrels
Post by von_lounger » Mon May 24, 2010 4:01 pm
Have you been able to find any of the 395mm Edgi TBB's in stock anywhere?  ASGI and KWA still don't have any  :'(
-Nick
[align=center]My Armoury[/align]
Stomper87
Re: EdGI Barrels
Post by Stomper87 » Mon May 24, 2010 4:06 pm
There are a few but there always out of stock. You'd be better off buying a new hop up chamber and a new outer barrel. Otherwise you either have to get lucky and find the right barrel or pay $150 for a custom made 6.01 tbb. You might be able to get a 407mm barrel and cut it...
P* Ares Tar21
P* PTS Masada
Magpul KWA lm4
KA Galil SAR
G&G UMP
G&P ak47
CA mp5a4
Esteban
Re: EdGI Barrels
Post by Esteban » Mon May 24, 2010 4:07 pm
They are in stock on KWA's pro shop. Follow the links.
Stomper87
Re: EdGI Barrels
Post by Stomper87 » Mon May 24, 2010 4:11 pm
Sorry, I didnt see that. I don't know much about EdGi barrels...
P* Ares Tar21
P* PTS Masada
Magpul KWA lm4
KA Galil SAR
G&G UMP
G&P ak47
CA mp5a4
Re: EdGI Barrels
Post by Dominum » Tue May 25, 2010 6:52 pm
Just bear in mind that if you want to use a barrel less than 6.03mm you will need to use very high quality BBs and keep it clean to avoid jams.
Esteban
Re: EdGI Barrels
Post by Esteban » Tue May 25, 2010 7:18 pm
Yeah, I clean all my barrels usually right after I use my gun for best results. I also use G&G and KSC BBs. I might just try out a 6.01mm and see if I like it.
