Scope for G3
CallsignRaven
Scope for G3
Post by CallsignRaven » Thu Nov 11, 2010 6:18 pm
I've been looking for a new scope for the G3 that I have been thinking about getting (thinking ahead *taps head), and I thought that these 2 sounded good. Any suggestions for one or the other or a different scope?
Option 1
http://new.rsov.com/product.php?langId=1&currencyId=1&manufacturerId=10&prodId=3594&cateId=74
Option 2
http://new.rsov.com/product.php?langId=1&currencyId=1&manufacturerId=10&prodId=4674&cateId=74
Thanks for any and all help!
IronChef
Re: Scope for G3
Post by IronChef » Thu Nov 11, 2010 11:20 pm
http://new.rsov.com/product.php?langId=1&currencyId=1&manufacturerId=10&prodId=12999&cateId=74
i have 2 similar to this...best for aeg dmr setup because u can change your objective view on the fly.
Re: Scope for G3
Post by Dominum » Fri Nov 12, 2010 12:10 pm
In airsoft, all you need is 4x. 40mm is preferred, though 32mm is OK. 50mm is unnecessary. Illuminated reticules are all well and good if you use them, I never use mine though. Same thing with MilDots, if you know how to use them and will, then get them, otherwise don't bother factoring it into your decision. What you do want in any case is a quality optic with accurate reticule adjustments (preferably external ones IMO). Go with a company that is known to make a quality product that won't fall apart or render a crappy sight picture.
