Batteries not charging
I have a Hitech IC battery charger and two 9.7 stick batteries. I hooked both batteries to the charger, one goes steady red than flashes red, the other does nothing!
Jeffrey "Huggies" Hughes
Sharpshooter- Echo 1 ASR (with left-handed mod), Galaxy MP5-K PDW
Veteran of Operations:
NONE YET
OIF/OEF/New Dawn Vet
NONE YET
Re: Batteries not charging
Did you mean a 9.6? I've never heared of a 9.7.... Anyway, is this charger a smart charger or a trickle charger? And what brand are the batteries?
P* Ares Tar21
P* PTS Masada
Magpul KWA lm4
KA Galil SAR
G&G UMP
G&P ak47
CA mp5a4
P* PTS Masada
Magpul KWA lm4
KA Galil SAR
G&G UMP
G&P ak47
CA mp5a4
Sorry its a 9.6... its a HiTec (http://www.airsoftatlanta.com/Hitech_Smart_Battery_Charger_Discharger_p/00552.htm) and its both a smart and trickle charger. The batteries are Intellect 3600s.
NONE YET
NONE YET
I have the same one hold the yellow discharge button for about 30-60 seconds.
Roses are Red, Violets are Blue, and so is your car at 102
If that doesn't work, flip around the settings until you get a solid green light. Give it a minute or two, and then flip everything back to what it should be. It seems that this "smart" charger has a problem detecting a battery with no charge. Once the batter has just a little bit of charge, it'll detect it and do fine.Hatch wrote: I have the same one hold the yellow discharge button for about 30-60 seconds.
OP: Domino(RF)
OP: Strategies of War (RF)
OP: Attrition (AF) (Co)
Looks like its working now! I moved the dial til I got a solid red light, then moved it back
NONE YET
NONE YET
Ack! Yah, I meant red:D Glad it's working for you now!J2H wrote: Looks like its working now! I moved the dial til I got a solid red light, then moved it back
OP: Domino(RF)
One battery fully charged, I think the other is beyond help... it won't even show ANY light when plugged in even when I move the settings around
NONE YET
NONE YET
- GREEN NINJA
I have this same charger, its a piece of crap. It seems the quick charge function 600 doesnt work properly and can fry your battery. I recommend only using the hi-tech charger on the 300 setting. It charges slower but I havnt had ANY issues since.
