G&G GR16 blowback spring question.
2 questions actually. My brother recently purchased a kwa sr10 which he loves. He put a TBB in it and purchased an m120 spring. I did some googling and it looks like the sr-10 is stock with an m120 in it already. So I was going to either buy the new one off of him or see if I could get his old one.
So on to my next question... In your opinion can the gearbox in a g&g gr16 blowback handle an m120 without breaking it? Currently it's shooting 340 with .2's but I would like to bump that up a bit to be able to use .25 more effectively.
Arms discourage and keep the invader and plunderer in awe, and preserve order in the world as well as property... Horrid mischief would ensue were the law-abiding deprived of the use of them.
Thomas Paine
Thomas Paine
Re: G&G GR16 blowback spring question.
G&G prolines can handle an M120 for a good while without problems. They are solid assault rifle gearboxes with the only real weakness being their wiring. The blowback versions of AEGs merely have a mod that attaches the "bolt" to the piston, it is not really much different than a normal AEG.
It's not a proline, it's a CM but I thought gearboxes were similar aren't they?
Thomas Paine
Thomas Paine
Still has good enough internals.
awesome, thank your sir
Thomas Paine
Thomas Paine
Just wanted to let you know that the KWA m120 spring is shorter than some/most aftermarket springs. Your cousin may still see a jump in FPS if he installs the aftermarket spring. Then again, with the FPS limits increasing a bit in 2011 for the AOSC, he may want to try something else. Just giving you options.
OP: Domino(RF)
OP: Strategies of War (RF)
OP: Attrition (AF) (Co)
I put it in mine
. And honestly, after he put the 6.01 in the sr10 it shoots like a dream so he's content for the moment.
Thomas Paine
Thomas Paine
Good deal!
OP: Domino(RF)
Though shorter, it is more robust to compensate.
