converting jg m4 to metal d-boys body
thebutnugget
Post by thebutnugget » Sat Jan 21, 2012 12:57 am
i have a jg m4 s-system i would like to convert and put the internals in a d-boys metal body but the outer barrel on the jg wont connect with the new metal body i think i might need a delta ring and a barrel nut and possibly a new outer barrel? if anyone can help me out please let me know asap! i can post pictures if needed
vanevery
Re: converting jg m4 to metal d-boys body
Post by vanevery » Sat Jan 21, 2012 1:01 pm
When you say "convert the internals" I assume you mean the gearbox, motor, and inner barrel/ hop-up.
Not the internals of the gearbox itself.
A standard m4 upper receiver , metal or plastic, will not accommodate a m4 S-System outer barrel and thus the RIS System. A m4 S-System upper receiver has what I would describe as a "contraption" piece that that is specifically made to accommodate its outer barrel.
The lower receiver is fine, it is just the upper receiver that you have to match up correctly.
You can buy this if you can find it in stock somewhere.
JG Full Metal Body for M4 S-System
http://www.airsoftgi.com/product_info.p ... ts_id=8532
Keep in mind that when you switch from a plastic (ABS) body and go to a metal body, you may need to buy a one piece hop-up unit. Like this: http://www.airsoftgi.com/product_info.p ... ts_id=4127
I think most metal bodies (lower receiver's) are designed for the one piece hop-up but not all of them.
matthewgoldberg44
Post by matthewgoldberg44 » Tue Aug 07, 2012 5:02 pm
did u have to get a new delta ring, outer baral or a new hop up
Post by SteevoLS » Wed Aug 08, 2012 5:41 am
The post right above your answered that question.
