LOCATION(S): Bluffton, SC
PAYMENT PREFERENCE(S): Paypal, Cash
ITEM(S): Annotated with Pictures
PRICE(S): Annotated with Pictures
DESCRIPTION(S): Annotated with Pictures
PICTURE(S):
VFC M4 E-Series Sold
Received in trade in October of 2011. Wired to Deans, everything is functional. In February the stock piston stripped, and was replaced with a Bravo Piston, along with a lube and shim job. Internally, the gearbox, motor, and wiring is stock save the aforementioned Bravo Piston, the inner barrel has been replaced with a Madbull 233mm 6.03 m and the hopup has been replaced with a Bravo Hopup unit. Externally everything is also stock, save the Madbull Mk18 DD Rails and some flip up front sight of unknown make.
Asking for $175 OBO
Hurricane 553 Reflex Sight SPF
Works great, parallax corrected to 150 yards. Utilizes AA batteries, has twenty different light settings, and can switch between green and red settings. Rear QD Lever snapped off after attempting to force it on the PTW Receiver, which boils down to user error I suppose, requires a quick weld job. The front QD lever is more than enough to prevent the sight from falling off however, but I will ship the rear in a small baggie to give the opportunity to weld if chosen to do so.
Asking for $65 OBO (If purchased in tandem with Chiclone x3 Magnifier with FTS Mount, combo price is $90)
Chiclone x3 Magnifier with FTS Mount SPF
Magnifier requires close eye relief, however it provides clear target picture and aligns perfectly with said Hurricane. The FTS mount performs admirably, and have not had an issue with it thus far.
Asking $35 OBO (If purchased in tandem with Hurricane 553 Reflex Sight, combo price is $90)
AMP x4 ACOG Scope SPF
Standard ACOG scope with x4 Magnification, standard crosshairs is easy to see in most situations, however the adjustable light settings allow you to illuminate the crosshairs in either green or red. Battery is however dead, and not sure what battery it takes however.
Asking $40 OBO
Magpul PTS Stock FG
Standard stock, inside sanded down slightly to accommodate a large buffer tube.
Asking $20 OBO
MAG M4 medium capacity magazine (x8) Sold
Can take 120 pellets, feed admirably, no standing issues with them.
Asking for $20 OBO
Magpul PTS PMAG medium capacity magazine (x2) SPF
Can take 130 pellets, feed well except for the last 5-8 or so. Not sure what the problem is.
Asking for $6 OBO
Classic Army M4 high capacity magazine
Can take 300 pellets, feeds well, trap door missing.
Asking for $3 OBO
A&K BMAG high capacity magazine
Can take 300 pellets, feeds well, wheel is hard to get traction with and turn on bottom.
Asking for $3 OBO
CYMA CM 30 AEP Glock SPF
A little worn and used, however still functions well, the only issue is in order to use the full auto function you must hold down on the selector lever.
Asking for $30 OBO
True Spec Chest Rig and Back Piece
Nothing truly special, what you see is what you get.
Asking for $30 OBO
Paintball Gloves
Perform as expected, excellent for CQB in my experience.
Asking for $8 OBO
Condor Plate Carrier OD Green
Has been through over 30+ games without a single issue, none of the fabric has ripped or failed. Sad to let it go.
Asking for $30 OBO
Condor Double Stack M4 Pouch Black
Nothing special, just a normal pouch with no noticeable wear.
Asking for $6 OBO
Condor Dump Pouch Black
It’s a dump pouch…
Asking for $6 OBO
Condor Triple single stack M4 Pouch OD Green (x2)
Works as advertised.
Asking for $6 OBO ($6 for both)
Smart Charger
Charges NiCd and NiMH. Automatic cutoff and connectors for large and small Tamiya.
Asking for $15 OBO (If purchased in tandem with Tenergy Battery, combo price is $30)
Tenergy Battery
9.6v 3800 mAH large battery wired to Large Tamiya, functions great, never had any issues.
Asking for $20 OBO (If purchased in tandem with Smart Charger, combo price is $30)
Voodoo Utility Pouch OD Green
Standard Utility pouch with compartments and netting for ease of division inside.
Asking for $6 OBO
Clone Surefire Flashlight with Mount
It might be a clone but when activated it is extremely bright. Requires CR123a batteries, none included. Also included with a rail mount.
Asking for $15 OBO
ACU Summer Jacket
Sized Medium Long
Asking for $10 OBO
ACU Summer Pants
Sized Medium Long
Asking for $10 OBO
ACU Boonie Hat
Sized 7 ¾
Asking for $10 OBO
PART OUT?: Yes.
ACCEPT/OFFER TRADE(S)?: PTW Items, Pelican Caeses, Functioning PEQ Boxes, besides that, realize I'm down sizing, but the worst I can say is no.
