THIS ALL NEEDS TO GO ASAP! I will sell it all right now for $200 Firm! Willing to part out, but only if the order is more than $25 and you do most of the driving. I will drive around 5-10 minutes at most, only because it would be a waste for me due to paying for gas.
Well L96:
Everything is stock on this gun. Never opened it up before myself, as I received it as payment for repairing a gun for someone.
The cheek rest is a jury-rigged one. The stock one was removed and replace with some cushiony one. It look decent, but can be easily taken off and replaced with the old one.
I do know that the sears are stripped. But everything else works fine on it. Comes with an ASGI scope. No bipod.
Pics: http://imgur.com/Hwxbz
WE CQB Master Hi-Capa
This gun is in new condition. Very little wear on it at all. Brought to one OP, but never used it. I have shot it a few times around the house for fun.
Comes with 3 mags, all perfect condition. Externally there is some wear, just from being in a tub of stuff. They DO NOT leak.
I will also include a MadBull Propane adaptor (the red metal one) and two cans of propane. One is 3/4 full and the other untouched.
ALSO I will throw in a cheap Crosman pistol for the heck of it. One mag. Not sure if it works but it uses C02.
Pics: http://imgur.com/Id8K0
http://imgur.com/IySnb
Parts:
Ok, I have a bunch of spare parts and crap. I won't go into detail with everything, but I will try my best to describe it all.
Parts for a complete gearbox. Nothing great, but it could be turned into a loaner gun. I know the gears are either stock JG gears or TM gears. It says XYT on them. Also including a random stock metal one piece hop up. Hnub and bucking included. Not great quality, but it works. Selector plate is a brand new SHS one. It isn't pictured but will be included.
Note: I can't seem to find a trigger spring. That is the only thing missing.
Pics: http://imgur.com/ebDYH
Completely disassembled Echo1 G36. The only thing missing is the hop up and barrel I believe. I think the whole outer barrel assembly needs to be replaced. Great for parts for a broken gun though. The gearbox is completely disassembled as well, but everything is there. It worked fine when I took it apart. The only thing wrong is the wiring needs to be soldered back on to the trigger contacts.
Pics: Internals: http://imgur.com/sqCwZ
Externals: http://imgur.com/FMfly
Stock set of gears (no idea on brand). One of the teeth is chipped on the spur gear.
Pics: http://imgur.com/dZO04
A bunch of motors. the one on the top is a G&P M120. Unused. The rest are stock motors. All the pinions are in good shape.
Pic: http://imgur.com/Im0qc
3 motor grips. No mounting hardware. Does include the heat sinks. Top one is from RDW. Middle is from CM Raider, Bottom from an SRC gun. I believe the heatsink in the middle is missing the motor height adjuster thing.
Pic: http://imgur.com/AvYYj
Magazines:
1 Dboys Hi-Cap
1 AIM Top Hi-Cap (brand new)
Gear/Other:
Helmet. Not sure of the brand, but I only used it a little bit. The side has a small hairline crack in it. Came that way when I got it. Also, the chin strap is a little finicky. I think one of the little buckles broke on it. Easily replaced.
I have a large head. This helmet is not for me. So if you are a smaller built person, this will work great.
I have also attached velcro to this helmet for patches and such.
Pics: http://imgur.com/4HJBk
http://imgur.com/aiOud
ACU BDU: Size is Large/Long. There is no rips or button missing. A little dirty from my last OP, but I will throw it in the washer tomorrow.
Pics: http://imgur.com/HBBfr
Hats and such.
Pics: http://imgur.com/vZzLz
ACU CamelBack. Actually issued in the army. Comes with cleaning kit and other accessories. I used it once, but it's been cleaned.
ACU vest. It's pretty low quality, but it's issued to the army. I have a few pouches on it.
Pic: http://imgur.com/1vOAw
Broken Thunder B. Missing spoon and the threads are stripped on part where the shell screws on to. Great for spare parts.
Pics:
Chargers. One Tenergy smart charger. Brand new. And one stock charger. Brand new.
Pics:http://imgur.com/0tfnt
http://imgur.com/pMvPS
Random scopes. Nothing fancy. One is a Beeman scope. Missing the covers for the dials. The other is a Tasco scope. Both in great condition.
Pics: http://imgur.com/ShjhB
I believe this is all for now. I don't have all the pics up right now, but I will post them when I wake up tomorrow. It's 3 in the morning so I'm going to bed.
Gear, Equipment, Parts, and a like new WE HICAPA. $200
Re: Gear, Equipment, Parts, and a like new WE HICAPA. $200
Bump
