wicked arch when fireing
truckman
Post by truckman » Sun Jan 31, 2010 2:42 pm
once the gun is fired the BB travels about thirty feet then goes straight down. i tried adjusting the hop up, it made it worst. does this sound like a bent barrel or something minor. pm me also this is a jg m4 all original
severed
Re: wicked arch when fireing
Post by severed » Sun Jan 31, 2010 4:40 pm
dirty barrel or ripped hopup rubber
Post by Dominum » Sun Jan 31, 2010 7:27 pm
...or the barrel is bent, the bucking slipped/rotated, the nub came out or is in sideways, the lever of the chamber is broken, the chamber is broken in some other manner, there is lube in the barrel/on the bucking, etc. Remove the barrel and check all parts in question, or bring it to either Grimwulf or myself.
IronChef
Post by IronChef » Sun Jan 31, 2010 9:18 pm
sounds like what happened to my umg....bucking was bad...but intead of going staright down....curved up after 20 ft
Esteban
Post by Esteban » Sun Jan 31, 2010 10:16 pm
Do you need directions on how to take out the hopup unit to investigate?
truckman
Post by truckman » Thu Feb 11, 2010 12:40 am
thanks guys i found the problem and fixed it good as new now..
Post by Dominum » Thu Feb 11, 2010 3:54 pm
...Care to elaborate?
