The Airfarm
Address: 470 Halfacre Rd. Newberry, SC 29108
Date:
Saturday, February 7th
Price:
$20
Itinerary:
0800: Registration and chrono opens
0915: Briefing begins
0945: 1st evolution begins
1200: Lunch break
1315: 2nd evolution begins
1530: 3rd evolution begins
17:30 Game ends
Scenario:
We are going to use a concept that has been tested on a small scale, and despite some reservations proved to be extremely workable and a lot of fun to boot. Here's how it works:
There are three roughly equal teams; Alpha (green), Bravo (tan/brown), and Charlie (balancers like black, ACU, civies, etc.). There are TWO respawns that are roughly equidistant from "the hill" (the point everyone is trying to control). One team begins at the 'hill', this team has NO respawn. The other two teams begin one each at the two respawns, respectively. All three factions attempt to take control of the 'hill' by killing everyone else there and then maintaining their position there for as long as possible by defending it. The defending team CAN'T hold it forever because they only have two medic heals each and nowhere to respawn (when one of them runs out of heals, they stand off to the side and observe until their team is overrun). Whenever a different faction takes control of the 'hill', the faction that previously held it then gets the respawn of the faction that just took the 'hill', and around and around it goes. What's the objective? To hold the 'hill' longer than the other two factions cumulatively. It's important that we have players bring a change of fatigues in case the numbers are not balanced so some people can change.
Here are the three sets of respawns and 'hills':
Respawns at bases 7 and 6, the 'hill' is base 2
Respawns at bases 14 and 6, the 'hill' is base 3
Respawns at bases 12 and 14, the 'hill' is base 10
Rules:
-Heal by tying bandage (provided) around upper arm, max two consecutive heals, all friendlies are medics
-Deadrags required to play (Available for $1 at game)
-Radios are recommended
-Stay hydrated!
-I highly recommend bringing a sidearm with no MED so you can clear fortifications
-AOSC games always go on as planned, no cancellations for weather
Map:
Important Reminders:
-You need to be IN LINE for Chrono and Registration BEFORE 0900. That means you need to show up at 0800, or 0830 at the very latest.
-SC Airsoft Supply will be vending with most everything you need in stock on sight.
