The Long Night @ Blue Hole 04/13/2018
Information about past games.
Locked
Post by Dominum » Thu Mar 15, 2018 6:57 pm
A 16+ hour night start, non stop scenario.
Directions can be found here
Or use 949 Richardsons Lake Rd Warrenville, SC 29851
Date:
Friday, April 13th and Saturday, April 14th
Price:
$25
Itinerary:
Friday:
1800 Registration and Chrono open
1930 Safety Briefing begins
2000 Game start
Saturday:
1300 Game Ends
Cycle yourselves out in shifts for meals and sleep, or better yet, eat and sleep in the field.
Scenario:
Each faction will have one permanent respawn that will not change and cannot be captured. There will be capturable respawns that may change hands throughout the game. The game itself will continue non stop, you may, if needed, return to the parking lot briefly to eat and/or sleep. Doing so in the field us preferable, however bear in mind eyepro rules may never be violated. Establishing a CoC for each faction and planning shifts for eating and sleeping, as well as common, is recommended. Long games of this nature are won by the faction with better communications and logistics. Objectives and spawn locations will be briefed on site.
Rules:
Night Game Rules (In effect after sunset and before sunrise):
-EVERYTHING on the field will be SEMI-AUTO ONLY during the night portion of play EXCEPT anything that has a 0 MED (under 300 FPS w/.25gs) AND is firing glowing tracer rounds.
-A colored glow stick (chemical or electric) is required to participate (it will be your dead rag)
-A flashlight of some kind is required (in case you or someone near you needs to be able to see in an emergency situation)
-All friendlies are medics
Important Reminders:
-SC Airsoft Supply will be vending with most everything you need in stock on sight
Entrance to Blue Hole
Sgt. Warthog
Re: The Long Night @ Blue Hole 04/13/2018
Post by Sgt. Warthog » Mon Apr 09, 2018 9:20 pm
It has been over 4 long years since I have been able to attend an AOSC event so I am really looking forward to attendng this one. I remember Blue Hole being a pretty awesome field. I am just wondering why there is no trash talking nor anyone saying they wll be attending. This event is on the up and up correct?
Post by Dominum » Wed Apr 11, 2018 10:24 pm
Yes, but activity has transitioned to FB for the most part. See you there!
Locked
