Directions can be found here
Or use 949 Richardsons Lake Rd Warrenville, SC 29851
Date:
Saturday, August 18th
Price:
$20
Itinerary:
0800: Registration and Chrono open
0930 Safety Briefing begins
1000 Game start
1330 Lunch Break
1430 Game Resumes
1730 Game Ends
Scenario:
Top secret. Be prepared for long-term objective based scenario play, focusing on the wooded portion of the field.
Rules:
-All friendlies are medics
Important Reminders:
-SC Airsoft Supply will be vending with most everything you need in stock on sight
Entrance to Blue Hole
