I used conservation of energy: squared the velocity of the .20 g, multiplied it by the ratio of 0.20 to whatever mass was in the column, then took the square root of that. Can somebody check my math?
OP Desert Locust vet.Inked wrote: A Fact of Life: After Monday and Tuesday even the calendar says W T F.....
Oh, I agree. But I should point out that these calculations are estimates of muzzel velocities, which are used to classify airsoft guns and assign them MEDs. Because so many people use heavier bbs to get a more stable trajectory, a lot of people are going to the chronos with 0.25s and 0.30s, etc, and the people running the chronos should have a handy chart to use for the sake of MED.D05GTO wrote: Looks good as a rough guide. Terminal performace would really show a better picture of what the different weigh BB's can do. Ballistics have a lot more details. Usually on ballistic charts you have to know the projectile coefficient (BC). What is a 6mm BB? No idea but I'm sure it's very very low.
Also, these are muzzle velocities. Biggest factor is the distance to impact and are very different for different weights in bb's. Just a made up example....Say a .10 leaves the barrel at 400fps and at 10 feet it's down to 300fps. A .20 may leave the barrel at 320fps and at 10 feet it will only be down to 300 fps. I noticed this is really pronounced with .12's at about 50 feet the BB looks like it's just floating in the air with no velocity at all.
Just some idea's.
D
Whole heartedly agree!Straightshot wrote: Instead of using a slide rule, sun dial and a wish, the person chronoing can just have a bag of .2s, to ensure all fps is accuartely measured. This has worked many times before.![]()
So brilliant, it could almost work!Straightshot wrote: Instead of using a slide rule, sun dial and a wish, the person chronoing can just have a bag of .2s, to ensure all fps is accuartely measured. This has worked many times before. ;)
You think I hadn't thought of this, already? Guess who has the ammo to spare for this for a chrono: ME!Straightshot wrote: Instead of using a slide rule, sun dial and a wish, the person chronoing can just have a bag of .2s, to ensure all fps is accuartely measured. This has worked many times before. ;)
[align=center]SteevoLS wrote:UN finger-wagglers such as Arbee are so intimidating they don't need no stinkin' gunpowder to take down the baddies!
[/align][align=center]ONE DAY I AM HOPE TO BE BESTEST AIRSOFT JOURNALISMIST EVAR[/align][align=center]http://arbeedoesairsoft.com[/align]
